DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 08-01-2009, 01:51 AM
justinsanders justinsanders is offline
Vehicle: 97 mtx built 2.4L turbo neon
Default what cars come stock with a 58 psi fpr
im trying to find me a 58 psi fpr for cheap im not gonna pay 90 dollars for one off modern. there are no 2nd gen neons in any junkyard around here. so im wondering what the stratus's had in them as fas as fuel. i dont understand y you need to run 24lb injectors or 58 psi fpr if you use the 2.4 engine in a neon if the stratus has the same injectors and fpr as a neon. if thats not tru please correct me. did the stratus come with a 58 psi fpr or larger injectors?
either way im looking for a car that came stock with a 58 psi fpr a 2nd gen neon is too new to be in any junkyards around here so what else did they come in thats older than them. i would like to run rrfpr but i dont have the time patience knowledge or money to do the spool boy mod right now i just want to supply my 2.4 turbo with enough fuel for now. i have 24 lb injectors in right now but apparently thats not enough so i need to find a 58 psi fpr please help me guys thanks...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
97 2dr mtx w/ 2001 2.4L enigine .020 over, no balance shafts, ross 8:1 comp. pistons, eagle rods, fully p&p head & im, 2.0 cams, big turbonetics turbo on 17psi for now, fmic, srt stg 1 injectors, spool boy mod, 4 puck racing clutch 2400lb pres. plate, no ac/ps componets. I WANA BUY AN INTAKE MANIFOLD
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-01-2009, 02:57 PM
Moparmatt440's Avatar
Moparmatt440 Moparmatt440 is offline
Vehicle: 04 SRT-4
You need to do a fuel return line system, and your running stock or stage one injectors on a 70 trim turbo??? You are way under fueled for that big of a turbo, I will be running a 60-1 and I am looking at 1000cc injec, course 750 are good but only if you want to stay around 20-25 psi, and my new turbo peaks at 32 psi. I built my own return line for about $250ish, and ordered everything through summitracing, but I got a OBX fuel rail off ebay. Do you have a wide band, curious to know what your afr are with that small of injectors
__________________
Old set up: dyno 303hp, 388 tqr w/ S2, full bolt ons and race gas+meth
Old 08-02-2009, 12:24 AM
i found a 58psi fpr and im running that and the 24lb injectors but it doesn't really help at all. but it doesn't make sense to me y it doesn't run when i give it more than 1/4 trottle even in neutral. it doesn't even barley boost in neutral so y would it run horrible before it boosts
__________________
Old 08-03-2009, 01:45 PM
12 volt's Avatar
12 volt 12 volt is offline
Vehicle: 98 neon sport
Quote:
mixture sounds incorrect
__________________
98 neon Sport SOHC/mtx, DOHC pistons, 95cam, audio system, toggle switch ignition, K&N insert
95 neon (parts car)
Tags
2001, 24, 98, daytona, dodge, fpr, injectors, lb, neon, open, psi, rail, stealth, stock, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
