DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 08-10-2009, 09:02 PM
MightyMouse1988 MightyMouse1988 is offline
Question 95 plymouth neon with just fixed now sensor trouble
I have a 95 Plymouth SOHC which i just fixe up after my water pump siezed, and snaped my timing belt. I had completely rebuilt the head. All new valves and had to replace 2 rockers. I also flushed out the radiator more times than i can count. My pistons are good and i have about 180 psi in all four cylinders. I was driving it for about a week and it was running great. Then i parked it one day and tried to start it up about 20 minutes later, and i got nothing. Its hard but i can get it to start and even idle. But when i try to give it some gas it just die's. It just boggs out. If i work the throttle fast off and on i can get it to rev up to about 4 grand then it acts fine sometimes or it will just keep trying to die. When i do this and i let it drop rpm, sometimes it goes back to idle and sometimes it just dies. Once i got it to actually start just fine and rev out perfectly but it only lasted for about 3 minutes and it went back to not wanting to run. I have replaced the air filter. I have not checked the compression yet but it does idle fine but only for a minute. So i dont belive its a compression issue. So i rented a OBD-II scanner from auto zone and i got 5 codes back.
It said they are:
P0505 Idle controle system malfunction
P0123 TPS/Pedel position sensor A circuit high input
P0108 MAP/BARO circuite high input
P0113 IAT sensor 1 circuite high input
P1294 Manufacturer controle fuel air metering
I have no idea where to start. Please help.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
1995, caravan, dodge, grand, high, input, p0123, plymouth, plymouth neon, position, replace, sensor, sensor problems, tpsthrottle, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
