DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 09-04-2009, 04:34 AM
ninjajuggalo18 ninjajuggalo18 is offline
Default car chuggings and stalling problems
i have a 95 plymoth neon sohc 5 speed
a few months ago it i would be driving and it would chug and wanna stall inless i gave it gas and if no gas it would stall or sometimes i would start it and it would stall right away inless i gave it gas when i started it it did that off and on for about 2-3 months now today it drove fine got to the store came out and it started but i needed to give it gas to keep it running then it stalled and would not start at all like the fuel pump whent out well i tryed agine few hours later gave it gas will tryin to start it it fired up with no problem what could the problem within in the lat 5 months all the follwing items have been replaced plugs, wires, fuel pump, fuel filter,clutch, head gaskets, within in 2 years the computer control has been replaced no i do know my neck filler looks really rusted and i know i have a gas tank leak if i fill it over half tank it will flow out know would could the problem be? i dont wanan buy gas tank and fuel neck filler and that not be the problem i know i need it but moneys tight need to get main problem fix please help me thanks in advance
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 09-04-2009, 01:26 PM
Altima_wb Altima_wb is offline
Vehicle: 97 DOHC 5spd neon sport
Send a message via AIM to Altima_wb Send a message via Yahoo to Altima_wb
any check engine light... if there is i would figure out what code it is and start there...
__________________
91 Chevy K1500 (current stock 305 to mildly built 350 swap in the works)
97 Olds minivan (wifes ride lol)
New Project 97 DOHC neon sport (Project daily driver :P)
Old 09-04-2009, 05:06 PM
Ghost Neon 2 Ghost Neon 2 is offline
Vehicle: neon
Also consider the possibility of a vaccum leak. Check your vaccum lines.
__________________
FS: Ported sohc heads for sale $255 shipped
Known mtx supplier for neons
http://www.youtube.com/watch?v=7-FRLtr35ZA
Old 09-04-2009, 07:18 PM
only time check engile light comes on is when it rains bad and i know thats the hole in the gas tank getting water in it new gas and its good there is no vaccum leakes i checked that but now i have noticed today that when my fuel pump fuse is in i here a buzzing sound coming from the computer (brain) if i tyake the fuse out it does not buzz i replaced the fuel pump relay thing that might be it and it did not make a difference and i was also able to get it started today and running fine agine i just wanna figer the problem out and start getting my 11 mouth child back in the car any other ideas it may be?
Old 09-05-2009, 12:00 PM
Vehicle: neon
Check engine wiring again. Something is getting wet when it rains. Something possible exposed.
You sure you are not fueling your car with Faygo?
__________________
Old 09-05-2009, 12:16 PM
lol yea im sure no faygo naw i think the check engine light comes on is is because water getting in the tank cuz if its on when it rans a day later and i put gas tretment or 93 fuel in the light will go off after drivin it for like 10 mins and it will stay off im thinking maybe the fuel rail might be clogged with stuff im not sure tho
Old 09-05-2009, 04:54 PM
i did the service engine thing and i got codes 12 and 42 so for 42 is it my fuel pump?
Old 09-05-2009, 11:05 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3 DOHCgarrett t3 is offline
Vehicle: 98 RT Neon Sedan
Send a message via Yahoo to DOHCgarrett t3
heh heh heh only made in Detroit?
__________________
Iceman CAI, 55mm TB, P&P intake, Indy head w/1mm oversized Valves, Crane 14 cams, Pacesetter headder, OBX LSD, Unorthodox UDP, Solid bobble strut. solid front motor mount. prothane motor mounts. Battery in trunk, KYB-gr2 w/Eibach Sportline Springs, Eibach Sway Bars, Every bushing replaced with Prothane bushings.
Tags
2002, 95, chugging, dodge, durango, engine, filling, gas, magnum, neon, problems, rains, stalling, start, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
