98 Dodge Neon Stumbles and Surges
Old 09-08-2009, 11:47 AM
brians1bad72's Avatar
brians1bad72
brians1bad72 is offline
Default 98 Dodge Neon Stumbles and Surges
I have a 1998 Neon, the car starts and idles fine, when I drive it, it will stumble and surge sometimes while taking off from a light or stop sign. I have a check engine light on, and I get codes po505 and po122 when scanned, I have cleared the codes through the scan tool, drive the car the light comes back on and the codes reset, I have cleaned and inspected th IAC, but no fix. Any help would be great, thanks.
Old 09-09-2009, 11:45 AM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
have you tried replacing the IAC or the TPS?
Also, I know those are the codes you are getting, but have you checked the spark plugs?
Quick Reply: 98 Dodge Neon Stumbles and Surges
