help with building a bastard of a motor.
I have a 97 dodge neon dohc. Need some help building a horse. No turbos.I have a couple sohc blocks but the pistons are diff. The sohc pistons are flat as the dohc ones are dished for valve clearance. How does this work with the swap? I wanna keep the dohc. Also what about aftermarket cams for this motor? How to set the timing? Will I need the Ecu flashed? Any stoker mods? Give me some options ppl. I heard this site is really helpful.
the motor is for a dirt track car. So that is why I know turbos. I know there's plenty of mods that could be done to a neon I just want some options.of course the head job porting and polishing and all that I know ofI'm looking for a little detailed stuff that I can do also like changing out the throttle body bigger injectors etc
Covers all those little things you need to know.
