first Gen neon instrument panel calibration
For what it's worth, I had to replace a pointer on my temp gauge which fell off. What I did, and have done in the past, is remove the gauge cluster, remove the cover to the gauge cluster, install in car and putting in only the two top screws to hold it in place, turn on the key, wait a few seconds and then simply install the pointers to where they should be. (obviously do this when engine is cold, the car is not running and fuel tank is filled so that it's makes things easy) This is probably not the correct way to do this, but it's never failed me in the past.)
