1997 Dodge neon ticking
Old 03-03-2015, 11:19 PM
Th3w01f's Avatar
Th3w01f
Th3w01f is offline
To Check your codes:
Put the key in and put it to the accessory position and turn it off then repeat that a total of 3 times. The check engine light will start flashing. Count the number of times it comes on and pair it up. For example: If the light flashes 2 times and waits then flashes 1 time, that means a code 21.
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02 sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Radiator Fan control relay circuit
37 Torque converter clutch solenoid CKT or park/neutral switch failure
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
Old 03-04-2015, 07:39 AM
jkeaton is offline
Dodge Forum Administrator
Well, learn something new every day. Thanks Th3w01f! So those codes he is getting (12, 55) mean there are no codes other than someone disconnected the battery. So, why is the engine light still on?
Old 03-16-2015, 11:45 PM
Th3w01f's Avatar
Th3w01f
Th3w01f is offline
BTW the only Code I got from an OBDii tool was P0340, which is a bad camshaft position sensor I assume (hopefully not a PCM problem) the car is a bit hard to start, and has a bit of a rough idle, also there has been a few times where it seemed like it jumped some as if it was close to stalling!
Old 03-16-2015, 11:50 PM
Th3w01f's Avatar
Th3w01f
Th3w01f is offline
Another issue I'm having, seen on this thread, is the rear driver side tire.
https://dodgeforum.com/forum/1st-gen-neon/385248-bad-wheel-bearing-hub-rear-driver-side.html
Old 08-19-2015, 11:28 PM
ClaytonH's Avatar
ClaytonH
ClaytonH is offline
Change the oil... High mileage Castrol 5w-30. Replace spark plugs with cheap Champion spark plugs and gap to 0.35.
Rocker arms do tick... Valve lash adjusters are known for it. Neon tick. You can pull the cam and rocker arms off a 99 Neon and it'll go away.
Pull the cam off and see if the lash adjusters are stuck. easier to replace the rocker arm than the lash adjuster. They should be sticking out and push in and pop back out. If they don't... replace them. It doesn't really hurt that it's ticking and you can get thousands of miles out of the head.... it's just that darn ticking noise!
Don't ever let your oil get that dirty again and it'll run until the fossil fuel on the earth is depleted. I swear by Castrol high mileage oil... At Wallymart you can get 5 quarts for $16 and a cheap $4 filter. Change every 4k miles. Even if the oil looks "clean".]
Amazon.com: Sannysis V1.5 Mini ELM327 OBDII OBD2 Car Bluetooth Diagnostic Interface Scanner: Home Improvement Amazon.com: Sannysis V1.5 Mini ELM327 OBDII OBD2 Car Bluetooth Diagnostic Interface Scanner: Home Improvement
Bluetooth OBDII reader. You can read codes and get live data from your sensors with your phone, tablet or laptop. I just leave it plugged into the OBDII port in my Neon. Always have it and my cell phone with me so it's available if I have to check other peoples cars.
Quick Reply: 1997 Dodge neon ticking
