drums to disk brakes
Old 07-01-2008, 03:31 PM
pure_instinct's Avatar
pure_instinct
pure_instinct is offline
Default drums to disk brakes
anyone kno how to take drum brakes and make them into disc brakes.
[8D]
Old 07-01-2008, 03:34 PM
mulletman11's Avatar
mulletman11
mulletman11 is offline
Default RE: drums to disk brakes
ur breaking power will not increase enough for u to know and the drums are lighter
its a bitch u need rotors calibers erake **** too much stuff
Old 07-01-2008, 03:37 PM
JackMehoffer69's Avatar
JackMehoffer69
JackMehoffer69 is offline
its not a worth while mod as previously stated. Some people believe that drums stop better than disks,but disk are more effieicent and consistant. rear breaks only do 15-20% of the braking anyway.
Old 07-01-2008, 03:57 PM
pure_instinct
umm ok how do u take drum breaks off and put disk on the rear of the car.
Old 07-01-2008, 04:00 PM
JackMehoffer69
ORIGINAL: pure_instinct
go somewhere else and find out. its a retarded idea no matter the reasoning. Go find a RT Neonand swap the parts off the rear, its a utter waste of time but go ahead and be a jerk off.
Old 07-01-2008, 04:12 PM
mulletman11
hhahahah
honestly man, give us all a reason why u want to switch?
is it cause u want ur car to be faster?
is it cause u want ur car to brake the same amount?
or is it cause u wanna view ur red spray painted calibers through your 14" steelies?
give us a benificial reason, were trying to tell u its not worth it, you will see(literally) nothing out of it.
Old 07-02-2008, 12:18 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Ghost Neon 2 is offline
ORIGINAL: JackMehoffer69
go somewhere else and find out. its a retarded idea no matter the reasoning. Go find a RT Neon and swap the parts off the rear, its a utter waste of time but go ahead and be a jerk off.
Kiss your mother with that mouth?
To the OP, best option is to find a neon (1G or 2G - doesn't matter) with rear disc brakes. you will need the rear disc brake lines, as they are different from the lines used with drum brakes. You will need something (flat head screw drive, pry bar) to remove the dust cap for the 30mm nut securing the backing plates to the hubs. Get the ebrake cables. They are the same as drums, but it is less work to just take them IMO. It is all really self explanatory when you get started. Expect to have to bleed brakes an adjust e-brake cables upon completion.
Just some pics to get you going: http://www.turbododge.com/forums/f4/...sk-brakes.html
Old 07-02-2008, 02:52 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHCgarrett t3 is offline
Jack and mullet you both should go screw yourself. we're here to help eachother, not to tell someone how they should do something they want to do.
Old 07-02-2008, 02:54 AM
DOHCgarrett t3
https://dodgeforum.com/m_806761/tm.htmthis will better help you in your quest.
Old 07-02-2008, 03:38 AM
j_son600's Avatar
j_son600
j_son600 is offline
Ok mullet here is one "beneficial reason" to switch, disc's are much easier to work on, change pads, maintenance and etc. You and jack should try to be a little nicer to new people. If there was absolutely no benefit to disc's do you think dodge would have wasted time putting them on the higher end neons?
Quick Reply: drums to disk brakes
