How to replace ignition lock / tumblers?
RE: How to replace ignition lock / tumblers?
ok my photoshop decided to crash so they ae a little bigger then i wanted so there will be a couple posts....but i just want and got the pics and here they are removal and install
[IMG]local://upfiles/29901/2FB9291AD8474F95926E447547AD6BD5.jpg[/IMG]
[IMG]local://upfiles/29901/5D2EF25084804EDB95DEC570A1F26902.jpg[/IMG]
UPDATE: I was not able to pull the tumblers out last night. Turns out that while I could turn the key forward a little bit, it was not enough to let me push the release pin. I had to remove the ignition switch from the lock assembly and got it to start with a screwdriver. I've been told a locksmith can pull the tumbers out with a special tool, so I guess that's my next step...
At least I can drive my car now!
first off you cant remove the lock without having the key, unless you brake out the lock...
now what you can do is use the screwdriver to turn the ignition on, then press the button and pull out whats left of the lock with a pair of pliers...then you can save alot of money by not having to get a locksmith
