DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
Old 01-28-2007, 09:48 PM
Bullet01 Bullet01 is offline
Default RE: DOHC Head on a SOHC Block
well I thank you for the advice! but dont you have to pull the block anyway to swap the pistons from a dohc block to a sohc block.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1996 copper Dodge Neon.
2.0 SOHC
5-speed
completely stock for now!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-29-2007, 03:17 AM
das2123's Avatar
das2123 das2123 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 96 ACR
Quote:
ORIGINAL: Bullet01
If you want to swap the pistons, you would...but you don't have to swap the pistons.
__________________
My For Sale Post
96 ACR
Old 01-29-2007, 08:56 PM
i was talking to a friend from work and he said that there were some cars that, all you had to do was remove the oilpan. and then remove the piston rods from the crank, then pull the piston down, remove the piston rod itself , then take out the rest of the piston. and then put the new pistons in the same way only reverse order. In such case you wouldnt have to pull the block. but that only works if theres enough of a gap between the crank and the side of the block. Now I personly havent been under my neon yet, I just got it last thursday. so I dont know if this would work in case with the neon. My friend swears up and down it will work. I myself dont think it will. Can you please shine some light on this subject for me.
Thanx
Bullet01
__________________
2.0 SOHC
5-speed
Old 01-29-2007, 09:24 PM
das2123's Avatar
Section Moderator
Vehicle: 96 ACR
^^^Oh, if only it were that freaking easy!!!!!
The rods and pistons have to be removed from the top.
__________________
My For Sale Post
96 ACR
Old 01-30-2007, 09:36 PM
Of course they cant make it that way, it would be 2 easy.
hey could any of you tell me if a gauge cluster with a tachometer will plug in to a 96 5-speed neon that has a guage cluster without a tachometer in it.
__________________
2.0 SOHC
5-speed
Old 01-30-2007, 10:26 PM
FastNeon84 FastNeon84 is offline
Vehicle: 96 Neon Coupe
Send a message via AIM to FastNeon84 Send a message via Yahoo to FastNeon84
yea. it will fit. i have a 96 5spd and did the same.
__________________
==1996 Dodge Neon SOHC 2d Coupe-project car
==2001 Plymouth Neon-grocery getter
==2006 Ponitac G6-work car
Old 01-30-2007, 10:36 PM
so it would be ok to do the dohc head swap with 2 mls head gaskets? how much more should i torque the bolts?
__________________
Old 01-31-2007, 11:02 PM
im not sure Ive never heard of someone using 2 gaskets.
__________________
2.0 SOHC
5-speed
Old 02-09-2007, 07:18 PM
highlinedude highlinedude is offline
is you car auto or manual if it is manual swap trans to the dohc has a better gear ratio,do not use 2 head gaskets you are going to turbo, you will have to swap pcm from same year,yes swap pistons too, i would look in a local junk yard 4 a dohc with a rear or side accident and do a engine and tran swap
__________________
98 highline
Old 02-09-2007, 07:26 PM
i have a mtx, im not swapping the pistons...that would defeat the purpose of lowering my compression....and the sohc trans has a better gear ratio for turbo applications.
__________________
Tags
block, change, compression, dodge, dohc, gasket, head, mustang, neon, plymouth, sohc, swap, swapping, turbo, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
