DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Cars > Dodge Neon > 1st Gen Neon
Thread Tools Search this Thread
  #21
Old 02-09-2007, 07:53 PM
highlinedude highlinedude is offline
Default RE: DOHC Head on a SOHC Block
sohc compression 9.8 to 1 dohc compression 9.6 to one
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 highline
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 02-09-2007, 08:16 PM
FastNeon84 FastNeon84 is offline
Vehicle: 96 Neon Coupe
Send a message via AIM to FastNeon84 Send a message via Yahoo to FastNeon84
but a dohc head on a sohc block will be lower than 9.6:1
__________________
==1996 Dodge Neon SOHC 2d Coupe-project car
==2001 Plymouth Neon-grocery getter
==2006 Ponitac G6-work car
  #23
Old 02-09-2007, 08:21 PM
really how so ??
__________________
98 highline
  #24
Old 02-09-2007, 08:33 PM
go herehttp://www.dodgeforum.com/m_599520/tm.htm
__________________
  #25
Old 02-09-2007, 08:42 PM
yeah that didnt help, but i found out and this iswhy you are right, sohc has a 54CC combustion chamber were the dull has 48CC combustion chamber
__________________
98 highline
  #26
Old 02-09-2007, 08:45 PM
oh..well that thread was just tellin you that it can be done withour swapping the pistons...and a parts list...
__________________
  #27
Old 02-09-2007, 09:20 PM
fullbuilt fullbuilt is offline
the dohc has a high compression piston to make up for the larger combustion chamber, the dohc on a single block will put you around 9.2 and the sohc on a duel will give about 10.2 and both are posable
__________________
1997 sport 1997 sohc and a 2003 sxt. there not exactly cute but much better looking than the calaber. what was dodge thinking.
  #28
Old 06-26-2007, 09:37 PM
mulletman11 mulletman11 is offline
Send a message via AIM to mulletman11
wait you guys areconfusing.
shouldnt putting a dohc head on a sohc raise compression. the higher the # the better.
the stock sohc has 9.8 to 1, shouldnt putting a dohc head on there raise compression, even though you dont swap pistons?? and if you did swap the pistons, then your compression should go up even more.
someone help.
__________________
'95 base, '98 r/t, '99 r/t, '01 pt loser, girfriends '00 se
My For Sale Post, check it!!
http://www.dodgeforum.com/m_1345211/tm.htm
My CarDomain Profile
http://www.cardomain.com/id/mulletrockshard
  #29
Old 06-27-2007, 02:09 AM
das2123's Avatar
das2123 das2123 is offline
Section Moderator
Dodge Forum Moderator
Vehicle: 96 ACR
Quote:
ORIGINAL: mulletman11
DOHC has 9.6:1 compression ratio, so why would it raise compression?
__________________
My For Sale Post
96 ACR
  #30
Old 06-27-2007, 04:51 AM
Slashwannabe Slashwannabe is offline
Send a message via Yahoo to Slashwannabe
you would want a DOHC head on a SOHC blockfor what logical reason?
Single overhead cam heads are better!!!!.... lighter more reliable andminimal power loss and less crank drag on pulling an extra cam shaft.People seem to forget they underated this motor (in the books not the product itself)as not to take away from the DOHC's introduction. The DOHC makes more seat of the pants power due to better factory exhaust andbetter computer settings, you put that DOHC head in your car and without the computer and exhaust it will feel a little less powerthan the SOHC, 10hp to be exact, due to loss of compression using lower compressionSOHCpistons with thebigger cc DOHC head and also the lack of the DOHC's computer and tuned exhaust.
The factory Dyno of both Engines prior to production was 144hp for the SOHC and 150hp for the DOHC and once the DOHC engine was introduced they docked the SOHC down to 133hp so people would have a reason topay more to upgrade to the DOHC.So to me it doesnt pay to have a less reliable engine that will cost more to build.
Don't get me wrong either motor is a good motor because there isnt much difference between them in the way of actual output if you were to throw each one on a dyno side by side,but for a more reliable ride the SOHC engine is better, your better off spending the $500the junk yard would charge you for theDOHC engine on $500 of upgrades to the SOHC engine and be faster.
Quarter mile times between the SOHC and DOHC are not much different,
DOHC RT Neon does 15.9 and the SOHC Neon Sport does 16.1 with a more restrictive exhaust and dogwater settings for the computer. Do yourself a favor and find a DOHC's computer install that into your current SOHC carand use its exhaust or buy a new performance Exhuast with Headerand you will still be under the cost of what it takes to rip apart your SOHC and buy a DOHC head and pull that and reinstall that motor. With that stock DOHCcomputer and performance exhaust your SOHCwill smoke any stockDOHC with no engine mods. Just swap exhaust and computer with a DOHC car and your ready to go!
Unless of course you allready have the DOHC head and lack a SOHC head then be my guest and throw it on
Tags
block, change, compression, dodge, dohc, gasket, head, mustang, neon, plymouth, sohc, swap, swapping, turbo, vintage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
