DOHC Head on a SOHC Block
  #71
Old 02-05-2012, 01:53 PM
das2123's Avatar
das2123
das2123 is offline
Originally Posted by Wally King Jr. #76
do i change from a sohc to dohc during a head swap from a sohc to dohc
, and is there a rpm curve difference in the two pcm's?
I assume you are asking if you switch pcms when doing the swap. If so, then yes it would be a good time but not completely necessary. Read the FAQs at the top of the forum for more info on the pcms.
  #72
Old 07-30-2014, 12:07 AM
protivakid's Avatar
protivakid
protivakid is offline
Does the list in the 1st post apply if I want to put a sohc head on a dohc block?
Other issues I may run into?
  #73
Old 08-02-2014, 05:21 PM
das2123's Avatar
das2123
das2123 is offline
No, it doesn't.
Quick Reply: DOHC Head on a SOHC Block
