Where can I find the identification numbers on my transmission? The white label on the front of the transmission is rubbed off and only has the numbers 088 016 on the top of the label. these numbers are the only numbers I can see.
Any help is greatly appreciated. thanks
In my 95 dodge neon I had the engine and transmission changed and dont even know which year the motor or transmission is.
oh yea 3500 rpm at 70mph, love it, lol, theres not much different between .81 and .72, few hundred RPM is about it, between a 3.55 from a SOHC and a 3.94 from a DOHC average is around 500 RPM difference in speed vs. rpm. it varies between gears and differnet RPM in each gear, but thats about what you get, if you drive in heavy traffic i would think the 3.94 would be a better choice for less clutch slipping and quicker acceleration
__________________
93 Talon TSi AWD 5spd- shootin for 11's
91 Talon 5spd
96 Neon sport coupe dirt track car
99 neon sport DOHC 5spd NEW pimp ride
07 CHEVY Silverado 2500HD 4x4
Automatics SUCK
Look on the very end of the gear box. You'll need to turn your driver's side tire to the left to view it. Brin ga paper towl as it should asoiled.
