1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
does anyone know if they make a 5 speed manual transmission for a 1990 dodge 3/4 ton four wheel drive with the360 engine. if not any clues as to what might fit. thanks
Find a 5-speed from a 90's 5.9L truck. It'll fit. If you're converting from an automatic you'll need to get the correct flywheel since the engine's externally balanced.
