1988 Dodge Ram 4x4 - DodgeForum.com
1988 Dodge Ram 4x4
Old 12-11-2008, 10:43 AM
daugherty
daugherty is offline
Default 1988 Dodge Ram 4x4
I'm looking for some technical help on an old farm truck that I use. While driving down the road my truck will just stall. It will start up after a few minutes of sitting idle. I have replaced the fuel filter and the fuel relay. I thought maybe I had if fixed, but on a test drive yesterday I found myself stranded alongside the road again. As usual the truck did start and after 2 incidences I was able to limp it home. What should I work on next?
Old 12-11-2008, 03:10 PM
dptyscott's Avatar
dptyscott
dptyscott is offline
Has anything been done to recently. ever replaced the ditributor'tunr it up,cecked cat converter9they stop up when they go bad somtimes. need to know more but thats a start.
Old 12-11-2008, 03:41 PM
1996Ram318's Avatar
1996Ram318
1996Ram318 is offline
I notice you said you have replaced the fuel filter and fuel relay. Have you replaced the fuel pump?
Old 12-12-2008, 03:39 PM
nemesis_SS
nemesis_SS is offline
when you stall and try to start it back up, what does it do? does it seem to be firing strangely, almost like it is missing some cylinders?
Old 12-14-2008, 02:03 AM
redneckokie1
redneckokie1 is offline
Default hall effect sensor (pickup coil)
i had that problem a few times with a ramcharger i drove for 300,000 miles. the pickup coil is in the distributor. look at the end of the wire coming out of the distributor for the correct one. most have the round plug with three contacts. you will need an offset phillips to replace it.
some of the web sites have the test methods for it but they are very inexpensive and should be changed if you don't know the history of the vehicle.
hope this helps.
Old 12-14-2008, 12:49 PM
lugnuts's Avatar
lugnuts
lugnuts is offline
Hard to diagnose in the ditch but maybe this'll help pinpoint the problem. No good just throwing parts at it.
Do the obvious and look for gas spraying from the injectors when you crank it. If you suspect fuel go to the boneyard and get some fuel line fittings etc. and rig up a gauge taped to the windsheild. Tie a light into the + going to the pump and put it where you can see it. No pressure and the lights on, relay control circuit's OK,wiring or pump. TBI pressure spec. is 12 PSI. If it is the pump, I find it easier to pull the bed off than to drop the tank. 8 bolts,tail light wiring, and 4 screws on the filler neck. Set the bed back a couple of feet. Much easier.
When it dies pull a plug wire and stick a screwdriver in it and hold it close to the mtr. Crank it and check for spark. Should a good blue spark at least a 1/2" long. Weak,red or yellow replace the coil. And like Okie said try the dist. pickup too.
It's also possible the Auto Shut Down relay's coming unlatched,in which case you'll have neither spark or fuel.
Old 12-14-2008, 05:06 PM
1996Ram318's Avatar
1996Ram318
I just cut a hole in the bed of my truck. And yes, I am serious.
Old 12-14-2008, 06:25 PM
nemesis_SS
Quote:
my brother did that in his blazer to work on the fuel tank. honestly working on old fuel tanks - especially in areas with wet winters and salt creating lots of corrosion - is a friggen pain.
so yea, 96Ram i hear you and second that cutting thru the floor.
Related Topics
Thread
Forum
Replies
Last Post
pamela24
Dodge Caravan
6
10-21-2015 06:33 AM
Ronald_Arif
Dodge Ram Van
4
10-07-2015 03:16 PM
ruben7913
2nd Gen Dakota
1
07-10-2015 06:00 PM
colons3499
Dodge Neon
0
07-09-2015 04:57 PM
carid
Vendor Group And Special Buys
0
07-07-2015 08:38 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
