Miles per gallon- What are you getting?
Old 03-26-2013, 02:28 AM
ol'dodge4x4's Avatar
ol'dodge4x4
ol'dodge4x4 is offline
Default back again
just thought id get caught up with yall. Built a flat bed for the power wagon and the mileage went down a bit. Now at about 15 - 16 on hyway. flat bed is heavier. Thought I'd ad, the motor is really close to 9 to 1 compression. I used magnum pistons and decked the block about .020. I used a mild rv cam made by melling. The heads are mid eighties 360 heads and so is the intake AND the carb. A Rochester Q-jet. I think this is the key to the fuel mileage, more compression and the Q jet. Actually the valves are larger on the intake! I used chevy valves, not tulip valves, for more compression, 1.92 intake and 1.60 in the exhaust. Used stock ford 5.0 valve springs. Stock 360 exhaust manifolds are used. I think that I could get a bit more mileage. I need to put a new thermostadt to try to keep the temp up to 190-200. I also need to tune the carb a bit more. Winter fuel also takes a hit on the mpg. BTW the pistons are made by Melling also. I did not balance the engine. Another plus for mileage is the heavy flywheel believe it or not. (think momentum). Oh well it has been cold this winter so I have not done too much to the truck but will start with some more tuning very soon. SEEYAA!
  #222
Old 03-31-2013, 10:48 AM
78moparman's Avatar
78moparman
78moparman is offline
my 2wd slant 6 in my 78 usally gets me 22 as long as i keepr around 50
  #223
Old 04-14-2013, 09:09 AM
briando's Avatar
briando
briando is offline
my ram is gettin pretty consisten 18 miles per gallon. i'm pretty happy with it, but i'm hearing the competition is in the 20's, kinda jealous
  #224
Old 04-17-2013, 12:18 PM
Katzen's Avatar
Katzen
Katzen is offline
with a crap airfilter and olds parkplugs that wernt gapped right i got 8mpg, once i replace it all ill find out how much i get after that, im hoping for 15-16
  #225
Old 04-17-2013, 01:26 PM
philipreza's Avatar
philipreza
philipreza is offline
Originally Posted by Mark.Kiefer
I have a 1988 dodge ram with a TB and a 318, i put on a larger air filter, an edelbrock performer and headers, and it took me from about 16 to 18mpg, and sometimes on the highway i get about 20... Its a truck though, I bought it to be a truck, not a cruiser, I am going to pull the computer soon and put on a 4bbl carb, so thats all going to go away.
What all have you done to you truck!? I'm trying to get better mpg!
1998 dodge ram high flow cat 40 series exhaust dumper air intake TB spacer
  #226
Old 04-17-2013, 01:38 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
6 mpg in town with the 400.
  #227
Old 04-23-2013, 01:36 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Sure makes a difference on HOW you drive. I get 16~17 if I drive carefully which I normally am. If I drive it like I don['t care what mileage I get, I get 12 or so. Makes a big difference in how often I need to visit the station. But then again I never let it get below half a tank.
  #228
Old 04-23-2013, 08:23 PM
beakerztoyz's Avatar
beakerztoyz
beakerztoyz is offline
I have a 85 w150 {4x4) with the factory 360 and 4 speed, I have headers and dual exhaust (2.25in) it has the factory 4 barrel rochester and a k&n filter I dunno what gears it has but today out on the highway she was gettin 18 miles per gallon I figure for a 28 year old truck with a carb thats pretty darn good.....
  #229
Old 04-24-2013, 11:14 AM
Sniper X's Avatar
Sniper X
Sniper X is offline
That is great for a 360 with a 4bbl. Do you happen to have larger diameter tyres than stock?
  #230
Old 06-10-2013, 04:57 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Default Weird...but good
I was in the little town where I go to do laundry and get gas yesterday so topped off. I had topped off right before I put my camper shell on last week. I had only driven 48miles but only used 2.4 gallons per my top off yesterday. that is an astounding 20mpg again! Admittedly it is up and down flate roads for the most part but that is pretty dang good for a 1991 W150 with a 318 4 speed. Last time I topped off I had gotten 18.8.
Quick Reply: Miles per gallon- What are you getting?
