Miles per gallon- What are you getting?
Old 09-12-2006, 08:46 PM
Jacob1's Avatar
Jacob1
Jacob1 is offline
Default RE: Miles per gallon- What are you getting?
I have what i think is a bone stock engine wise and the usual (spark plugs, battery, wires, etc.)
1992 Dodge Ram 150 LE with the 5.2L 318 motor. I am currently getting 22-25 on the highway and not much less than that in town.
  #22
Old 09-16-2006, 07:50 PM
rogertc1's Avatar
rogertc1
rogertc1 is offline
Well with the Holley carb and better air flow system I gained a whopping 2 MPG average for my 1984 Ram, 318 to....12MPG average.
  #23
Old 09-19-2006, 11:59 AM
rogertc1's Avatar
rogertc1
rogertc1 is offline
regulay unleaded gas today 9/28, @ Davenport IA 2.05 gal.
  #24
Old 10-27-2006, 04:41 PM
dodgedakotacrazy's Avatar
dodgedakotacrazy
dodgedakotacrazy is offline
1992 Dodge D350 Singlewheel D60 Rear with 3.55 gears 5spd gets 22 around town if not gettin on it. don't know what highway is haven't drove it a long distance. yeah its a cummins i turned the pump up a turn.
  #25
Old 11-02-2006, 08:40 PM
edbama2's Avatar
edbama2
edbama2 is offline
05 Hemi quad cab automatic 18Mpg country road driving
83 Ram W150 360 engine 4WD automatic regular cab 17Mpg automatic country road driving
  #26
Old 11-03-2006, 10:55 PM
rogertc1's Avatar
rogertc1
rogertc1 is offline
What type of Carb you have on that 360 4wd to get 17MPG...I am doing something wrong??
  #27
Old 12-17-2006, 12:51 PM
wtrussell's Avatar
wtrussell
wtrussell is offline
I've got an '89 ¾ ton 4x4 with a stock 360. It's used for camping with a 10½' camper on it. Last trip to the Uinta Mountains I got 6mpg. Man, would I love a new cummins diesel.
  #28
Old 01-08-2007, 04:11 AM
topsites's Avatar
topsites
topsites is offline
I'd say consistent maintenance and a feather light throttle foot are the key.
The '86 D-250 318 2bbl got 14-15mpg while towing a 6x12 landscaping trailer around the county.
That's with Accel HP (HighPerformance) Cap and Rotor, double platinum plugs, Taylor 8mm HP wires, a Flamethrower coil, and a 14-inch HP air filter.
Oh, oil change every 3k, trans fluid and filter every 10k, fuel filter twice in 50k, pcv valve and breather cap twice also.
Greased wheel bearings once, lubed all the zerks at least once (maybe twice), flush and fill radiator once.
Keep all 4 tyres filled to the Max. psi printed (on my truck, 50psi).
Mythbusters or not: Replaced tailgate with a rubber mesh one.
Always run Premium 93 octane namebrand (BP or Texaco).
And I take it real light on the throttle, drive like granpa.
Dunno on the '95 with the 360 yet, too early to tell (just got it), thou I expect much of the same (14-15mpg with trailer) since it's running 10w-30 Synthetic racing blend and has multiport EFI (+ same mods as the '86).
Only thing I miss is dual exhaust and racing headers, but then I'd need dual cats (so, expensive).
  #29
Old 01-14-2007, 08:17 PM
1niter's Avatar
1niter
1niter is offline
I get about 8 on the interstate. However i do know that if you take a stock 318 and rebuild it to stock specs except drop in an r.v. cam 4brrl card about 650 cfm with vacuum secondarys and put a dual plane intake you can almost double your mileage. I've done it. Dodge always has put to small ofn a carb on their motors.
  #30
Old 02-28-2007, 12:43 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Kev_n_AZ is offline
93 D250 5.9L diesel gets 19 to 21 in city and with freeway traffic. have not had it on long trips yet.
(btw, it has 333500 miles on it )
Quick Reply: Miles per gallon- What are you getting?
