1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have the smog pump (the last pic part) and is missing the belt and most of the hose. Has the top part with the hose the is like a (S). The neg battery cable on mine is hooked to the back of the pump. Where did you put the cable and can you post some more pic? Thanks
sorry, been working alot lately and havent had a thought to check the ol' DF. but its dark out at the moment but could provide pics tomorrow. and as far as the battery cable goes, mines was already connected to the bolt on the front driver side manifold so i had no issues with relocation. and no problems with electrical connection either.
on both of my trucks the ground wire is bolted to the head. if you do go through all the work make sure to clean everything good so that you get a very good ground connection.
What about the remaining items, the Charcoal Canisters, EGR, EGR Delay Valve, CCEGR Valve, Vacuum Solenoid, Vacuum Amplifier, and the items on the air cleaner?
From my '82:
Howdy, Let you know about that Diagram is actually made in Chrysler. Hope you didn't get confuse.
Hi. I Got a smog pump for my 79 dodge d100 truck 318 4bl
I need the adapter for the hose and pulley. I'm sure there's other stuff I might need.
Does anyone know about this?
Thanx
