Replacing front brake discs, 1989 W250 diesel
Helo
Can someone tell me how I replace the brake discs, aka how do I remove the old ones? Do I need to dismantle the bearing hub, or is it just to remove the caliper and carefully knock the disc free from the hub with a rubber hammer or similar?
regards
The N.
regards
The N.
Here is a write up on a 1/2 ton but it is essentially the same:
http://ramchargercentral.com/article...iew;article=14
You need to be careful knocking out the wheel studs so as not to damage them or just buy new ones.
You will need the special "hub" spindle nut socket to remove the retainers, while doing this it is a great time to clean, check or replace and repack your wheel bearings and seals.
Remember to follow the factory service manual with regards to re-torquing the spindle nuts - remember the specs in the above article are for a standard D44 not your Dana 60\61
As far as the special socket it isn't specifically a "size"...they have prongs on the socket to engauge in the retainer. Here are some examples:
http://www.toolzone.com/acatalog/Too...kets_2856.html
Which one you need depends on which axle you have; your truck could have either a D44HD or a D60 dependin on the options.
Trending Topics
The socket does not have a size designation like most sockets. It is a special socket that has four **** inside that fit in the four notches on the round nuts on the axle. The pictures show the nuts. This site shows the socket, I prefer the sixth one down because it is self centering.
http://motors.shop.ebay.com/__?_from...p_id=774816316
When I did mine, I had to use a little penetrating oil to get my wheel studs out. Like SEAL said, thread a lug nut on the stud as much as you can without having any threads come through... You do not want to mushroom out the threads on your studs. Use the same lug nut for all of the studs, that way if it gets ruined, you only have to buy one. Also, there are two different rotor options, one has a taller hub than the other. At least that was the case for my '85 1 ton.
