Quits when very cold
my 75 used to have a big idling problem even on warmer days.. it wouldn't stay running at all till the truck got hot.. i would check your choke.. i think 88 its pretty close to the same.. make sure the pull off and the choke itself works. then after that i would adjust the carb.. maybe just turn the idle up a bit. i did those things on mine and now it idles right when i start it even on really cold days.
btw on my truck the choke pull off wasn't working, so when i got the new choke the choke would be on most of the time. i had to move the vacuum line to a different part of the carb
If choke was staying on most of the time you need to adjust your choke.
Here is info on that http://www.slantsix.org/articles/cho...oke-adjust.htm
I would also call these guys http://www.slantsix.org/forum/viewtopic.php?t=12996 and see if they have one for your setup.
I have one on my 86 slant and it makes big difference.
Dave
Trending Topics
