My new truck has some (3) codes
Hi: New truck is now in the garage and runs pretty nice. I have been appreciating your input on some other issues.
I checked the codes and I have 3: 12, 45, 17
12 I don't think is an issue.
45 says overdrive solenoid is shorted or open. I have no idea what that means but it sounds not too good.
17 seems like a tstat issue. Am I right?
Thanks
Mike
Thanks
Mike
Well thanks for that info. I suspected the tstat as it ran pretty cool bringing it home from Jax to Bqk about 70 miles. Otherwise seems ok except the PO installed a new muffler and ran the tail pipe out of the center muffler towards the ground. So it only has about 1/2 length of the exhaust system. I better not sit in it too long at idle.
He also put in 1 fill of synthetic Transmission fluid. I am still wondering if that is bad. Should I do a 3 drain and fill or just let it go. The color is very good.
Betting they put synthetic and some friction modifier or other additive because it was slipping or shifting bad. I would leave it alone.
