'92 W250 died on highway
92 W250 360 gas w/automatic transmission
Ok, the truck dies while on the highway. Felt pretty lucky to be able to cost to the shoulder. There was no prior warning, no other issues leading up to this.
Got it to the shop and checked for spark and had none. I have got no fuel pulsing at the TB.
Its been a while and can't remember if I bypassed the ASD but one way or the other I could hear the fuel pump to work.
Basically I am debating if I have a computer problem or some issue with the ASD. Planning on heading out here in a few to try and see if I can figure anything out.
If anyone can point in a direction to check that would be great.
Thanks,
Steve
Thanks,
Steve
Ok here is what I checked out. I can get the ASD relay to click if I put 12V to it off the battery. But, I do show 12V at the plug for the relay but it will not click when I plug it in. Also I can jump the ASD plug and get the fuel pump to run.
When I try to turn the truck over it cranks but I am still getting no spark.
Is there something in the distributor that can cause this whole mess? I feel like I am missing something easy.
Note: I am not even getting the few seconds of run time out of the fuel pump when the key is first turned on.
Trending Topics
Thanks,
Steve
Thanks,
Steve
