not starting
Old 03-26-2014, 06:54 PM
cumminsman123's Avatar
cumminsman123
cumminsman123 is offline
Default not starting
hey guys my 93 w150 is not turning over and i dont hear the fuel pump turn on and i just put a new ignition switch in it
Old 03-26-2014, 10:07 PM
grantshultz1994's Avatar
grantshultz1994
grantshultz1994 is offline
check the ASD relay
Old 03-27-2014, 04:54 PM
cumminsman123
thanks and just so i know what does asd stand for
Old 03-27-2014, 07:00 PM
grantshultz1994
Auto Shut Down relay... goes off ignition switch and crank sensor... f working correctly it will shut off your fuel pump and such after about 2 seconds of not receiving a crank signal from the crank sensor...
also have you checked all your fuses?
Old 03-28-2014, 06:33 AM
cumminsman123
yes i have and i checked the power to the fuse box its 12v where is this relay located
Old 03-28-2014, 05:01 PM
grantshultz1994
Old 03-30-2014, 11:50 PM
Comrade General's Avatar
Comrade General
Comrade General is offline
If its not turning over then I wouldnt worry about the ASD too much.
Is it an auto or manual? manual trans have a clutch safty switch that can go bad.
Could easily be the starter relay or the solenoid or starter itself. Check your voltage going to the starter on the ignition wire, if you have power there then its your solenoid/starter. You can jump connectors to tell if its the solenoid.
Old 03-31-2014, 03:27 PM
grantshultz1994
a faulty clutch safety switch will not cause the fuel pump to not turn on
Old 04-06-2014, 12:03 PM
cumminsman123
Ok guys do y'all think it could be the computer
Old 04-06-2014, 02:42 PM
grantshultz1994
hen you turn key, does anything else come on like radio or blower motor?
Quick Reply: not starting
