Ignition coil specs
Ignition coil specs
And one have the ignition coil specs for a 360 la throttle body motor? In attempting to test my coil but don't have proper equipment to test in the truck so I have to do a bench test. With out an owners manual my data will be pointless. I've tried looking it up but so far no luck. Any help is good help. Thanks in advance
well since you're gonna do a bench test set your volt meter to ohms, touch the positive terminal to positive lead and negative to negative, if its between 1-3 ohms its probably good. thats for primary windings. to test secondary windings: negative to negative, and put positive lead into coil wire hole and it should be between 6k and 30k ohms. that's just a general spec in my tune up book for college... I don't have my service manual on me that's locked in my tool box in the shop. ill look for exact specs tomorrow morning and get back to you but if your itchin to get some answers RIGHT NOW then that's a general spec for ignition coils
Trending Topics
