1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I'm changing the engine from a 318 to a 360. The truck is a stick and I know the motors are balanced differently would I have to get a new flywheel or will the one from the 318 work?
Your going to need a new flywheel, because the 360 is externally balanced, and the flywheel on your 318 is neutral because the 318 is internally balanced
