1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
which gasket did you use on the front of the pan? i believe my gasket set for it came with 2 diffrent gaskets for the front, one is for newer trucks, is it possible you used the wrong one?
