1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Where is the voltage regulator on this truck.Every part store tells me I have the normal type that is usually on the fire wall but its not there.Ive seen some threads that say its part of the IM but im not sure.
I have never heard of the IM, but your voltage regulator is in the computer or ECM.
I was referring to the Ignition Module or computer if you like.Is their any way around buying a new computer. The truck runs good but it shows the alternator is only feeding the battery 12.5v on the truck,off the truck 14.5v
