New 1986 W150 5.2L owner w/ questions
as for the kickdown arm on the trans. on the stock 2 barrel it had a little pin it went onto with a small washer and a clip that held it on. as you pushed the throttle it would move that backwards towards the rear of the truck, and at full throttle it woould move it back far enough to downshift the trans. into 2nd gear, and then you will haul ***. not being hooked up, it will not downshift to 2nd gear when you floor your accelerator.
Thank you rebeltaz83, i did plug the hose when i set the timing only because i read it on another post last night. So with the hose plugged the timing is right but with it plugged back into the carb the timing will appear way off right? And since the kickdown hooks to the throttle im assuming that i have to find some kind of aftermarket hookup since the carb, throttle cable, brackets, and cable are all aftermarket. And im going to get on the headlights this afternoon after work, thanks again.
Sorry KCChiefs....cannot get an angle good enough to take a pic of the linkages. The access ports are too small for my phone or tablet to get the angle needed to take the pic. If you good it, there are diagrams out there and there are also ones on youtube (dakotas mostly) that may help.
Good luck!
Good luck!
Ty guys for your help so far. I have another problem now. The headlights on the truck were not working when i got it but the turn signals, brake, and running lights work. I just changed the control switch and i tried new headlights and still nothing. I dont have power at the lights. I have power on 3 pins going into the control switch but im not sure what those pins coincide with. Any suggestions? Wiring harness for the lights messed up somewhere maybe?
