1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
My 74 power wagon that has a 360 with a 4 speed trans will not start I have checked power I have power to everything I have changed most of the electronic stuff ( ballast resister,ECM pickup coil) it will still not start now I don't know what to do. Does any one know what I should do next? Thanks
Yes the starter will spin i forgot to add that and the the engine will turn over but not start but when you turn the key back to off its like the engine trys to start.
Have you checked to see if you have spark? if so is the timing off? Have you put a little fuel down the carb to see if it tries to start? Three things that make an engine run. Compression, ignition (properly timed) and fuel. If you have those three things, it has to run.
