1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
when i put a 360 in a 1982 250 HD where a 318 was. it looked like the frame had holes for a big block mounts. i got a extra long bolt for the one top left bolt at the block. and got a long turn buckle that fit from the bolt to hole in the frame. but had to tap the bolt longer than the length it came. and trapped the block and motor mount with two nuts. and bolt head facing forward. that way the turn buckle can not slid off. no chain. no mods to the block. it looked good. i think the bolt was 7/16. for some reason chrysler likes 7/16 bolts. go figure.
