318 timing problems
318 timing problems
Anyone have problems with the timing marks lining up for a 79 power wagon. The maker line up 180 out to fire. Cannot correct it with the distributor it will not start. Anyone know if dodge something different for that year. Because the books way does not work. Did they make both side. I haven't takin the cam gear or cank gear off
Did you ever have the distributor off? It can go back in two ways, and is very easy to get it in backwards (I have way too much experience with that!). Maybe double check that the plug wires in the distributor are in the corect orde. There were some small blocks that you timed off the passenger side, but I think that was early '70's?
Did you ever have the distributor off? It can go back in two ways, and is very easy to get it in backwards (I have way too much experience with that!). Maybe double check that the plug wires in the distributor are in the correct order. There were some small blocks that you timed off the passenger side, but I think that was early '70's?
