1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
has anyone tried to install a GM HEI ignition on an older gen 1 mopar power wagon? i found a website today that explained how to bypass the resistor block useing a GM HEI system. just wanted to see if anyone here has tried it.
hey thanks for the response, i just finished up wiring in the GM ignition module. i ended up using a ford hei coil (only because i already had on on hand). it runs better than ever. if you go with a gm module, you have to run a different coil because the stock mopar coil cant handle a full 12 volt charge for very long, and apparently that is why the used the resistor block.
