Alternator overcharge battery
I have a 1992 Dodge D150 6.9 L the Battery was boiling today and I checked the voltage with truck running and it was over 15 volts going up to over 16 with motor at higher rpm. I have begun to believe that this is a voltage regulator problem. The voltage regulator is in the Computer?? is that correct. Where is the computer? Where can I buy a used (preferred) or new? Low on funds Please advise thanks
Here is the answer to your question and solution to your problem.
http://store.alternatorparts.com/hd-...ement-kit.aspx
Dave
Dave
