1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Just bought an 86 dodge w 150 and while trying to start the brake line are getting hot like burn Hand hot!!! Checked everywhere can find a wire open ohm read 5.7 on frame drawing power somehow any ideas
Im thinking more like you have a wire that has rubbed through and is making contact somewhere. Try removing one fuse at a time from your fuse block and see if the frame power goes away. If it does, then you know which circuit is the culprit.
