Aftermarket Wheels for D-150
I'm looking at getting new wheels for my '85 Ram D-150. Most aftermarket wheels are a lot wider than the stock steel wheels, that is OK as long as it will clear.
Stock height truck with a rear leveling kit. I'm looking at 17"x 8" wheels with a 4.488" backspacing and no offset and 255/60R15 tire.
I think they will clear in the rear no problem but, up front I'm not sure.
17" Tire/wheel conversion
go to tire-size-conversion.com and enter your stock tire size. see results as it gives you the option to change wheel size (ie 17"). I changed from 15" wheels to 16" wheels. My truck is in paint shop. I will check tire size and let you know. Also I had to use wheel spacer/adapter to use aftermarket wheels.
Note: the bolt center (not bolt circle) is larger on these trucks than most wheels. You can also get the results on the backspacing/offset the the adapters. I had plenty of wheel well space. I have stock springs on mine. newtjr
