Transmission leak
Transmission leak
I have what is believed to be a 1990 transmission hooked up to a 93 318. I can't remember the year of the tranny might be able to find out later if it is important. My tranny is leaking above the neutral safety switch and I can't identify where the leak is from. I haven't actually caught it leaking when I clean it but after I walk away the fluid is off the dipstick and every thing is covered again. Just need some ideas because I don't want to pull the tranny for a leak.
I bought the shift shaft seal remover tool. Made it super easy just pull the linkages off. Although buy the 1" longer , mine came up short. You'll need a 6" c clamp as well. I haven't got to testing it out yet been working to much. When I put my seal back in it didn't go in 100% straight. I'm hoping it'll still seal.
