What sensors do I need? Carb 318
I have a 90 d150, putting a carb 318 engine in it. I have an oil pressure sensor and water temp on the way. Is their anything else I need? I can't think of what else. This engine is completely bare when it comes to sensors and wires. It is a crate engine. The truck was originally TBI.
Those two should be it. Though you will need a fuel pressure regulator to dumb the pressure down to around 6 psi or so. Whatever carb you get should tell you in the manual what pressure you need. Something I'd really suggest, especially with a new crate engine, would be an HEI set-up. I got a distributor with 8 mm wires off eBay for I think $80. It made a huge difference on my warmed up 360. Everything is inside the dist., so just a one wire hook up.
