1977 727 torque converter seal
Anybody know what is the correct torque converter seal for a 1977 w150 318 with a 727. The seal I pulled out is a national k9927rer and every parts store I take it to they can't get it and I end up with a drive works 331227h and its just a little bit too small
What part is to small? Rockauto has this same # listed 331227
Alternate/OEM Part Number(s): 15527598, 1942020, 3515137, 4531225, 8122839, 8124869, 9309204, T1795
Info i found for it...
http://www.skfextranet.com/Catalogs/...il.asp?s=18592
If this info is wrong you can find it at Chicago Rawhide/SKF. They can get any seal know to man.
http://www2.chicago-rawhide.com/
My guess is that your trans or pump housing was changed since the one for the 77 is to small. See if you can get the year of the trans or pull the old seal and get some measurements off it(you will need a caliper). Use the link to get a part #
http://www2.chicago-rawhide.com/popu...kup_457010.htm
Just about everything that Chrysler made has a casting date on it. It's usually a circle with the last two digits of the year inside it. I forget when they stopped putting the vin # on the side but you may want to look for that also. That would be on the drives side on the flange that the pan bolts to. Not sure if different year pump housings are interchangeable so the best bet would be to remove the old seal and get some measurements on it.
