1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Going from 2WD to 4WD is a completely different story. 4WD uses a front axle that can use coil springs or leafs(depending on how it's designed). It doesn't work the other way around. I guess if you completely redesigned the control arms,frame etc... you could make it work. Not worth it when you can just use a coil spring(as the factory did). To convert a 2WD to a 4WD you need to remove all the the brackets/etc for the control arms and weld on everything to use a front axle(leaf spring mounts).
you need to find a whole truck that been rolled and do a body swap and what ever else you want to keep or use and put whats left on CL or make trip to the scrap yard
