Does anyone know when the Magnum 360 started being put into use?
Old 05-20-2016, 08:13 AM
thunderz's Avatar
thunderz
thunderz is offline
Exclamation Does anyone know when the Magnum 360 started being put into use?
I have a 1990 Ramcharger and was under the impression that it was the LA? Danyone know if that is correct or is it a Magnum? Is there a way to tell visually?
Old 05-20-2016, 08:31 AM
jkeaton is offline
Dodge Forum Administrator
LA was replaced by the Magnum in 1993.
Old 05-20-2016, 08:35 AM
thunderz's Avatar
thunderz
thunderz is offline
Do you know what the differences between the magnum and the LA are?
Old 05-20-2016, 08:41 AM
jkeaton is offline
No. Probably could google it.
Old 05-20-2016, 08:45 AM
thunderz's Avatar
thunderz
thunderz is offline
I have been reading and from what I read the entire engine is different short of the crank shaft and block. I am curious to know if anyone has put a magnum into a truck that originally had an LA motor.
Old 05-20-2016, 05:06 PM
The War Wagon's Avatar
The War Wagon
The War Wagon is offline
Lightbulb
It's a popular swap. Get the wiring harness & ECU. You might want to do a gas tank swap as well, as the fuel pump is probably in the tank in the Magnum. The pump WILL be different from TBI to Magnum.
Old 05-20-2016, 05:09 PM
thunderz's Avatar
thunderz
thunderz is offline
Oh...ok. Very cool. Thanks!
Old 05-21-2016, 01:21 AM
Moparite's Avatar
Moparite
Moparite is offline
Do some reading and all you questions will be answered.
http://www.magnumswap.com/first-steps/
Quick Reply: Does anyone know when the Magnum 360 started being put into use?
