Putting a turbo on my ram?
Old 11-06-2016, 08:15 PM
Turbo ram's Avatar
Turbo ram
Turbo ram is offline
Default Putting a turbo on my ram?
What would I need to put a turbo on my ram and not blow it up. 5.9L magnum
Old 11-06-2016, 08:26 PM
jkeaton is online now
Dodge Forum Administrator
Lots of money.
Old 12-31-2016, 01:17 PM
ARobinson93's Avatar
ARobinson93
ARobinson93 is offline
I'm just about finished installing twins on the 360 in my 87 D150. For twins you need turbo headers, waste gates, turbos, filters for the turbos, oil feed and drain lines, new exhaust, new intake piping, a blow through carb and then just small odds and ends.
I did mine fuel injected. So what I did was used everything above, but am running it off a Holley EFI ECU, using a multi port intake manifold, injectors, water methanol injection, and added a blow off valve for longevity.
Old 12-31-2016, 06:45 PM
Moparite's Avatar
Moparite
Moparite is offline
Where's the pics?
Old 01-05-2017, 02:52 PM
ARobinson93
I did a build thread on yellow bullet you can check out. It's obviously not done yet, but the fuel injection is all wired up, turbos and manifolds are installed, and really its just about ready to fire.
http://www.yellowbullet.com/forum/sh....php?t=1959874
Old 01-05-2017, 07:05 PM
Moparite's Avatar
Moparite
Moparite is offline
Interesting build, What did you do to the bottom end of the motor? Forged crank i hope.
Old 01-07-2017, 08:16 PM
ARobinson93
Just a stock engine right now. I'll be running 7 psi and it should be just fine. I'm planning to build a 408 with an aftermarket block to start making some real power down the road
Old 02-04-2017, 11:25 PM
moparborn's Avatar
moparborn
moparborn is offline
Default Going twins here as well
Twin turbos are this winters project.
Will be running Fitech system.
Old 02-07-2017, 03:40 PM
HeyYou is online now
Received 3,177 Likes on 2,930 Posts
Oh man. That's PRETTY.
