Rear mounted steel fuel tank
Hey guys Ive got an 87 w100 with the plastic tank that's offset to the drivers side and its cracked/leaking so I decided to scrap that(since you can't buy a replacement) and go with the ramcharger type rear mounted steel tank but yet again no one makes them anymore so I've been channeling my inner Roadkill engineering(you tube show if you don't already know about it. check it out!) I'm going to try and find a fuel tank from another Chrysler product that would fit in between the frame where the spare tire would normally go with the filler neck exiting out the front drivers side corner and uses the two wire sending unit and mechanical fuel pump. So far Ive found that a f-150 tank from the same era would fit but they used electronic fuel pumps so the sending units are not the same and I don't want to get into changing wiring harness's and gerry riggin sending units. So I'm starting this thread in hopes that somebody out there has faced this similar issue and found a Chrysler solution that could help me out.
https://rover.ebay.com/rover/1/711-5...3D361149170378
What about something like that? not sure of the measurements between the frame rails
https://rover.ebay.com/rover/1/711-5...Uf%26vxp%3Dmtr
Not sure if the sender in this one will work or not.
