Starter trouble
Old 01-30-2017, 03:26 AM
Nstaugler's Avatar
Nstaugler
Nstaugler is offline
Default Starter trouble
Got an 88 d350 the starter clicks but wont turn over. Its a new starter and the starter switch on the fender was just replaced what could be the issue
Old 01-30-2017, 02:18 PM
Noelie84's Avatar
Noelie84
Noelie84 is offline
If you hit the key more than once does it just click every time, or does it eventually catch and go?
Old 01-30-2017, 11:23 PM
Nstaugler's Avatar
Nstaugler
It clicks one time never catches and goes. The terminals are tight battery is new I'm puzzled with it
Old 02-01-2017, 08:14 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Have you tried jumping it with another car? The battery itself might be too weak to turn the starter over, but it'd still run things like the radio or the dash lights, door buzzer, etc.
Check the ground cable (runs from the block to the battery, typically) for any damage or corrosion, since a bad ground won't let it turn over.
Another option is to try running a jumper from the starter terminal to the positive terminal on the battery. You can use your jumper cables for it. Clamp on to the positive terminal on the battery, turn the key to 'run' and touch the other end of the jumper to the starter terminal. If it starts, you've got a bad neutral safety switch (or a clutch switch if it's a manual). This is what I'm leaning towards for a cause, to be honest. If everything else is good this is a pretty common cause of a no-start.
Old 02-01-2017, 08:41 AM
Nstaugler's Avatar
Nstaugler
Thanks I'll let you know but everyone is saying the neutral safety switch. Hopefully that's it
Old 02-03-2017, 03:27 PM
Noelie84's Avatar
Noelie84
Noelie84 is offline
Keep us posted!
Old 02-08-2017, 05:04 AM
Nstaugler's Avatar
Nstaugler
neutral safety switch didn't fix it either
Old 02-08-2017, 09:11 AM
Noelie84's Avatar
Noelie84
Noelie84 is offline
That's a bummer. Have you tried running a jumper wire from the battery directly to the starter to see if that'll spin it?
Old 02-10-2017, 04:18 AM
Nstaugler's Avatar
Nstaugler
Its actually the ignition switch on the lower part of the steering column
i know its held by 2 screws but how does it come off
Old 02-13-2017, 11:10 AM
Nstaugler's Avatar
Nstaugler
Still just one click at starter if anyone one is from miami county ohio let me know i need this truck for the farm. Having no luck and ive sunk 350 in it so far
