Well, I spent part of my long Thanksgiving weekend under the truck in my garage pulling stuff off to get to the transmission. I basically have just a couple things left to do and was looking for some help. All the wires going to the transmission, is there a main plug that I can undo to disconnect them all at once if not, is there a trick to removing them. Also the linkage seems a little tricky help there would be appreciated too.
So far, exhaust Y-pipe off, just unplugged the O2 sensor and left it on the Y-pipe. Transfer case off, needs service also. Drive shafts off, starter off, torque converter cover off and torque converter unbolted. All bolts holding tranny to engine have been loosened, but not off yet. Tranny drained and pan put back on and coolant lines disconnected at the tranny. Cross brace still needs to come off then I think just the tranny.
Thanks!
