06-16-2009, 02:57 PM
Nice glad to see someone else, with intrest in these trucks
06-17-2009, 03:10 AM
was the truck a 440 to beign with? people are always asking about what is required to make the swap
__________________
'91 D150, standard cab, standard bed
'63 Rambler American 330
06-17-2009, 04:59 PM
Vehicle: Soon to be a D-150
All I can see that would be required is motor mounts, a tranny, tranny mounts, and possibly a driveshaft.
06-18-2009, 06:05 PM
yes. but they want like a step by step thing, with detailed info. there are always so many questions that just pop up. (this bellhousing, that tranny, driveshaft length, i dont know, all sorts of little things).
__________________
06-30-2009, 10:28 AM
Vehicle: 87 dodge d150
hey !!!!!!!!!!!!!!!!!!!! man that is a thing of beauty. I have one question does anybody have any idea how much and where to find a big block 421 hemi? even if it needs repairing I don't have a lot of money to spend on it, but have lots of time. this is going to try to be for a 87 D150. What mods have to be made? check out my thread "lifting and finishing the dodge"
06-30-2009, 01:36 PM
Vehicle: 96 Ram standard cab, short bed, 318 auto. tranny. 87 D100, long bed, 318 auto. 87 5th Ave. 318.
I assume you mean a 426 hemi. Just a good bare block would be quite expensive. Nothing to try on a low budget build.
Pontiac had a 421 but it wasn't a hemi.
__________________
Grandpas like toys too
06-30-2009, 02:56 PM
I went from a 360 to a 400 in my 83 Shortbox. Driveshaft worked fine so did the trans mount. All you need is Bigblock truck mounts(2wd for 2wd and 4x4 for 4x4 they were diff)If you had a smallblock youll need to lengthen the coil/distributer wires if you go 440 you need a bigblock booster( If you have power brake otherwise dont worry remember a 440 has a taller deck hieght that the 383/400s) and youll need adequit cooling. I used the radiator that was in it and it suprisingly kept it cool. Pic of the 83 and a pic of it ready to pull from a 2wd 87 Ramcharger
07-03-2009, 06:31 AM
Love it 440 69
U PICK THE BEST OF THE BEST BLOCKS
NEXT TO THE CROSSBOLT HEMI 1964
MAKE SURE A HIGH VOLUME OIL PUMP GOES IN
8 QT OIL PAN WINDTRAY SEVERE PLUS
ASK DICK LANDY
SO WHATS THE GOAL OF YOUR ENGINE
STREET ,STRIP, PLAY , RICER KILLER
GO TO YOU TUBE AND PUNCH IN (BURN OUT 2)
DODGE TRUCK FROM HELL
IF U NEED ANY HELP AT ALL JUST ASK
Tags
1964, 440, conversion, d100, d150, dodge, engine, headers, motor, mounts, swap  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
