1991 dodge d150 with an engine and transmition from 87 dodge b250 and under the hood harness from 1986 or 1987 d150. in order to use the wiring harness from the 1991 i would have to get a new intake manifold. plus i would preffer to keep it carburated which is simpler than throtlebody. i really would like to know i there is a ballast on the 87 dodge d150 with the computer.
Where is that 1987 B250? I need a grille, or at least the RHS headlight bezel (plated version preferred).
BTW My 1987 B150 has a 4 pin ECU and a two connector ballast resistor. Many of the carbureted versions (up to '88) had that split SMEC system that tucked one part inside the driver's side fender.
