DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 1st Gen Ram
Thread Tools Search this Thread
Old 11-06-2009, 02:28 PM
Reps'87Ram Reps'87Ram is offline
Vehicle: 1987 Dodge Ram 360 4X4
Exclamation Leaf spring issues!
I drive a 1987 Dodge 150 4x4 360. I have a typical North Eastern salt issue on the under carriage of the truck. Unfortionately, the salt is winning Anyway, with that said, I have leaf spring issues. In my last post, I wrote about how the leaf spring came dis-lodged from the frame rail hanger, and how and where I can purchase used or new hangers. Well, I found slightly used hangers and purchased them for pennies on the dollar!! Now the issue at hand is tearing apart the used hangers that have everything included. (the last owner just cut off the leaf with a torch) Should I replace the leaf spring bushing? Can the bolt that is through the bushing be removed or does it have to be cut off? If I replace the old bolt, can I just use a grade 5-8 bolt in it's place? Is there anything else I should know about this task at hand? Please offer any advice and / or help for my continuing saga... Thanks again for your time!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-06-2009, 04:10 PM
dodgetrucker75's Avatar
dodgetrucker75 dodgetrucker75 is offline
Vehicle: 08 dak. 4.7 trx4
just get a good look at the bushing, if its cracked or coming apart i would replace, but they are a little difficult to replace, shouldnt have to torch the bolt, and a grade 8 bolt should be plenty enough
__________________
98-12v converted from v10,afe stg.2 intake,"custom" fuel plate & afc,ddp 3 injectors,4gsk. twins 62/68/13 over 75mm s400, rack plug, 60lb. springs, stg. 2 water/meth
75 power wagon w/1st gen,custom built jammer injectors,pump adjustments,twin turbos, water/meth, arp studs. 08 dakota, 4.7L
Old 11-06-2009, 10:29 PM
BLKRAM3 BLKRAM3 is offline
Vehicle: 1999 Dodge Ram 2500
Sorry i didnt get back to you sooner at you old post, snooze you loose!
Grade 8 bolts are what the dealer would sell you, but you'll get them cheaper elsewhere. You'll need to grind off and puch out the factory rivets that fastened the old mount to the frame (assuming they are still the original mounts) as for the thru bolt, i had a pretty tough time pulling it out of the old bushing, and chances are everything is rusted to crap anyway. I would say save yourself the headache and go new. i would also reccomend hitting the frame up with some rust converter or rustoleum before you bolt the new mount on.
Old 11-06-2009, 10:34 PM
JollyRoger85 JollyRoger85 is offline
1989 Dodge Ram 100
My Garage
Vehicle: '89 Ram / '99 Dakota
I agree definitely go with new hardware. I went through the same thing when I put my lift on. Everything's rusty and nothing works like it should... Grade 8 is the way to go.
__________________
Old 11-07-2009, 12:10 AM
Thank you all for the info. VERY HELPFUL!! I have been working on tapping out the old rivets on the broken hanger. Trust me, NOT fun! I allready purchased Black rustoleum, and I am going Monday to get the grade 8 bolts. Keep checking back for future posts from me and my rusty Dodge project! Oh yeah, I will be posting pics soon. Thanks for all your help.
Old 11-07-2009, 08:20 AM
1989 Dodge Ram 100
My Garage
Not sure how you're getting the rivets out but I did mine pretty easily with a torch... just get a 3/8" piece of rebar or something and a hammer, heat them up red and smack them with the bar... they come out surprisingly clean, I was skeptical at first but it worked well.
__________________
Old 11-08-2009, 03:03 PM
Thanks for the info! I tried grinding off the rivets and just ended up getting frustrated!! I am going to try heating them up this time and punching them out! Thanks again for your help! To Be Continued...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
