DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 1st Gen Ram
1st Gen Ram '93 & Older Rams
Thread Tools Search this Thread
Old 11-20-2009, 08:09 PM
mhetrick89 mhetrick89 is offline
1990 Dodge W-Series
Vehicle: 1990 Dodge W250 360
Default 16's to 15's
I have a 1990 dodge w250 gas. I want to take my 8 lug 170mm off set of and down them to 15's. what would i need for an off set?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 11-21-2009, 01:31 AM
AeSix AeSix is offline
why?
any cost savings in rubber will cost you in fuel. not to mention the better selection for 16 inch rims.
I'd try to stick with the same off-set, or maybe a little smaller if you're planning on more narrow wheels than you have now, and a bit larger if your getting fatter tires.
Either way I wouldn't deviate from 170 too much.
but thats just me, wait for crazywolfie
Old 11-21-2009, 03:17 AM
crazzywolfie's Avatar
crazzywolfie crazzywolfie is offline
Vehicle: 91 dodge d150 shortbox carburated 318
wait for me? you pretty much covered what he asked with the info given. in order to give a more accuret answer we would need to know the size of the current 16inch tires you have and the size of the 15's you plans on using. i would also like to know why you would want to do this?
Old 11-23-2009, 03:52 PM
dodgetrucker75's Avatar
dodgetrucker75 dodgetrucker75 is offline
Vehicle: 08 dak. 4.7 trx4
depending on what kind of drums you have in the rear may not allow you to install 15's, i have run into this a few times before on 3/4 ton's, but cant remember which vehicals they were
__________________
98-12v cummins converted from v10,nv4500,twin turbos,triple wastegates,heavily modified,
75 power wagon w/ 1st gen cummins, twin turbos, getrag, heavily modified
08BLACK TRX4 dakota,4.7L,lift,exhaust,SC 3865, cai,33x12.50 toyo M/T's on 18x9 rockstars
Old 11-25-2009, 07:17 AM
be easiest, I'm thining, to just do a rear end swap. Might need to change the yolk on the new rearend or on the drive shaft (probably be easier on the rear)... IF you even have to do that.
Leaf springs aren't as much a pain as coil springs to release from the frame, then there's the break fluid line and the parking break wire. pretty simple.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
