2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Avenger 2nd Gen Do It Yourself information
Old 05-30-2011, 01:42 AM
steak59's Avatar
steak59
steak59 is offline
Originally Posted by guapoman2000
Thank you! Will check switch as I don't believe my Brake Fluid level is low enough to cause the senor to trip but, if so, it must be a really sensitive sensor!
Carlos
Well, The fluid sensor has a Float Bow like ur toilet in the fluid bottle, with a Magnet attach to it. if the fluid is "kinda low", it'll swing low enuff to trip the switch when you go over bump or going uphill/downhill.
when you replace it, you replace the outside sensor. The one with 2 wires going into it.
Old 05-30-2011, 01:46 AM
guapoman2000's Avatar
guapoman2000
guapoman2000 is offline
Yeah, I know and thanks.
I will check in the morning for the brake fluid level.
Bumps are not causing any chime / BRAKE Light to go ON.
It is only in tight turns and going down hill in a highway exit ramp.
I know which one causes it and it is like clock work!!!
Glad to learn that I do not need Brakes!!!
Thanks again!
Carlos
Old 06-05-2011, 12:24 PM
guapoman2000
Default Seems like the Brake Fluid was low!
Okay good people!
During a Trip to Miami, Florida and West Palm Beach from Orlando, Florida this past weekend (Saturday, June 4th, 2011), I finally stopped into a Miami, Florida DISCOUNT-ADVANCE AUTO PARTS and they connected their Computer CODE hand held device and all was okay and no ugly codes were detected. They performed the read twice to make sure the procedure was done correctly.
I bought one pint of quality Synthetic DOT3 Brake Fluid and the AUTO Parts employee topped off the Brake reservoir. We noticed that it took right around 3oz. to Top-Off the reservoir.
Once back on the road visiting family, I happen to find a expressway exit ramp that forced the car in a tight Right hand turn and NO chime NOR "BRAKE" warning was noticed on the DASH!
Seems like this solved the issue!
Thanks!
Carlos
Old 09-28-2012, 10:03 AM
Derson59's Avatar
Derson59
Derson59 is offline
I have that issue too. I am about to go do that as well.
Old 09-28-2012, 07:42 PM
steak59's Avatar
steak59
steak59 is offline
Make sure you get your brake pad inspected before you do that. Most of the time is because your brake pad linings are low. The brake reservoir lines are designed to go to LOW when your brake linings are worn. You top off the bottle, you could be just masking the problems.
Old 10-27-2012, 01:15 PM
Gregory Biamby's Avatar
Gregory Biamby
Gregory Biamby is offline
Does anyone know how to fix a daylight running lights problem my running lights dont go off after I start the car and the signals and high beams and low beams and wiper dont work?
Old 02-03-2015, 12:37 PM
stevemcc0322's Avatar
stevemcc0322
stevemcc0322 is offline
I USED 2012 DODGE AVENGER 2.4L AS OEM MODEL. I USED 2012 DODGE AVENGER RT 3.6L AS THE RT BASE LINE AND THE 2012 CHRYSLER 200 TOURING 3.6L AS THE OTHER SOURCE. KEEP THAT IN MIND WHEN READING THIS.
please also note that none of the sources that I have used has been able to provide thickness of the parts. I can fill in what I know but that is it.. if you know the others then please update
Front sway bars :
4670526AA Chrysler 200 touring…
(68080525AA RT same part number as SXT)
Rear sway bar:
4670519AA Touring Suspension sway bar (fits all cars listed)
68089521AA Sport Suspension sway bar (fits all cars listed) ******
Bushings rear:
OEM 5272649AC RT & avenger
5168021AA for 200 touring
Bushings front: 5168245AA for 200 // sxt // and RT
Front end links (OEM 5174185AC same on all cars.. 10.5 inches long and 8 MM thick.
Rear end links (OEM 5174245AD same on all cars) 3.25 inches long and 8 MM thick
Adjustable rear upper control arms rear : SPC 67018 will work on all cars listed
Camber kit front SPC Performance EZ Cams 81260 will work on all cars listed
Old 11-30-2015, 11:41 PM
Libby's Avatar
Libby
Libby is offline
Default changing gear **** light in console on 2011 avenger
just bought t from private party and found it had no light in the shifter panel only the one of the dash
any assistance on how to change it and the bulb info would be greatly appreciately
Old 12-02-2015, 12:08 PM
jkeaton is online now
Dodge Forum Administrator
You should start your own thread.
Quick Reply: Avenger 2nd Gen Do It Yourself information
