2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Dodge Avenger lighting problem
Old 11-07-2008, 11:16 AM
marcel08's Avatar
marcel08
marcel08 is offline
Default Dodge Avenger lighting problem
I have a 2008 dodge avenger, the rear tail lights turn on when I turn on the main switch, I checked all fuzes and the rear light bulbs, but there are no negative indications, so everything is actualy good. When I brakeor turn on the turn signals the lights will not turn on. What can it be? And what wires can i check?
Old 11-07-2008, 12:11 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
There are TWO filiments in the bulbs , one is the running lights the other is the turn signal /brake "light"
Do your FRONT turn signals work ???
Does the third brake light come on ???
Old 11-10-2008, 09:17 PM
marcel08's Avatar
marcel08
marcel08 is offline
Thumbs up For those who have problems with rear lights,brakelights, and rear turning signals
For those who have problems with rear lights,brakelights, and rear turning signals I found how to fix the problem without paying!! After I posted the topic about my 2008 Dodge Avenger I went ahead and decided to see the closest Dodge dealer nearby. All you have to do is ask them to run a scan on your vehicles computer and they will do it. While performing the computer check they said there were errors in the signal and brake line. So they were able to RESET it. After all it will be a happy ending!!!
If its anything electrical to do with the car, dont even bother calling the main Dodge Headquarters because they were worthless.
Old 06-28-2014, 08:27 PM
teenie's Avatar
teenie
teenie is offline
I have a 2008 dodge avenger, the problem I have is , the tail light on the diver side is not working I changed the bulb , not the fuse neither, can you help me plz
Old 06-28-2014, 08:33 PM
teenie's Avatar
teenie
teenie is offline
all my lights are working ecxept the driver tail light
Old 06-30-2014, 11:02 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
Did you check the wiring to the tail light lamp for possible short?
Old 01-14-2017, 02:06 PM
Tidus x30's Avatar
Tidus x30
Tidus x30 is offline
Question 2008 dodge avenger 2.7L left rear tail light not working
Hi i have a 2008 dodge avenger
My rear left turning signal is not working i got a 3157 bulb
From canadian tire and changed it but still nothing.
I took off the extended part of the socket and tested it and only
Got a reading of 2.10 when its supposed to be 12v from what
I have been told.
I am not a mechanic and dont know a ton so any advice would be appreciated as i cant figure out the problem.
THANKS.
Quick Reply: Dodge Avenger lighting problem
